Advertise VRRP in EIGRP
dwaynepeeters
Hi all,
I have two routers running VRRP, where the Virtual interface is the default gateway for the internal clients.
I was wondering if it is possible to only let the "master" router advertise the virtual interface in EIGRP.
So that if VRRP switches and the other router, the other router becomes the master and starts advertising the virtual interface.
I'm trying to accomplish that remote routers at other offices know which router is at the HQ is the active on.
Any help would be much appreciated,
Kind regards,
Dwayne
dwaynepeeters
I have the network design beneath, and what I basically want is the following:
When the master (the router on the left) loses it's internet connection, VRRP switches over to the router on the right (with object tracking). Then the router on the right needs to send a triggered EIGRP update to the router at the branchoffice (bottom) so that the branchoffice router immediately stops sendings it's traffic to the router on the left and starts sending it to the right.
Hope this clarifies my problem a bit.
Again any help would be much appreciated.
