advice for Nexus Core
gianluca811
I have a layer 2 lan with low latency device 10 Gbps.
I need to replace the 2 core switches from another vendor to Cisco Nexus as far as I already have 2 access switch Nexus 3546.
Requirement: buy 2 nexus low latency where connect 2 access cisco nexus 3546 + other access switch (other vendor). Multicast very important. Need at list 32 ports SFP based  for each switch.
What kind of Cisco Nexus do you suggest to buy ?
nagasheshu2010
32 ports? what kind of ports? 1G or 10G or higher?
Sheshu.
SFP based
So I can put 10 G fiber or 1 G copper and fiber
I am not sure nexus 5k support copper directly, may be you need to use additional media converters probably.
But I could find these options.
Cisco Nexus 5548P Switch
The Cisco Nexus 5548P Switch  is the first of the Cisco Nexus 5500 platform switches. It is a one-rack-unit (1RU) 10 Gigabit Ethernet and FCoE switch offering up to 960-Gbps throughput and up to 48 ports. The switch has 32 1/10-Gbps fixed SFP+ Ethernet and FCoE ports and one expansion slot.
Cisco Nexus 5548UP Switch
The Cisco Nexus 5548UP (Figure 2) is a 1RU 10 Gigabit Ethernet, Fibre Channel, and FCoE switch offering up to 960 Gbps of throughput and up to 48 ports. The switch has 32 unified ports and one expansion slot.
Cisco Nexus 5596UP Switch
The Cisco Nexus 5596UP Switch (Figure 3) is a 2RU 10 Gigabit Ethernet, Fibre Channel, and FCoE switch offering up to 1920 Gbps of throughput and up to 96 ports. The switch has 48 unified ports and three expansion slots.
All three devices support both IPV4 and IPV6 milticasting with IOS version
n5000-uk9.7.3.0.N1.1.bin
hope this helps?
Sheshu.
