advice
Hi ,
I have two subnet , Both of them pass through the Same VLAN interface, I need to give priority for the packet from the first subnet to pass through this VLAN , So how i can lable these packets with high priority .. Thanks in advance
devils_advocate
Level 11
Level 11
Can you share the config of the VLAN interface?
Presumably you mean a secondary address on the SVI for the second subnet?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There's a difference between labeling a packet for different treatment and treating a packet with special treatment.  Which did you want to do, or do you want to do both?
In your case, you can classify your packets by their subnet address, and mark them as needed.
Also in your case, as the packets pass through your VLAN interface you can treat the packets from different subnets differently.
The prior assumes your equipment has the necessary QoS feature support.
How the above would be actually accomplished depends on the platform.
PS:
BTW, there are recommendations for labeling packets, but just labeling them doesn't guarantee they will receive "high priority", and what "high priority" even means is up to your QoS policy.
