After Changing Default VLAN ID, Can't Delete VLAN 1
dtheese
On my SG200-26 switch (firmware version 1.4.2.4), I have changed the default VLAN from 1 to 20. I have removed every trace I can find of VLAN 1 in the switch's configuration, yet when I try to delete VLAN 1, I get this error:
"VLAN 1: VLAN can not be deleted because IP Interface or DHCP relay is defined on the VLAN.."
What else do I need to do to be able to delete VLAN 1?
7 Replies 7
Leo Laohoo
VLAN 1 can never be deleted.
I had the pleasure (sarcasm) of working on a S500 (similar to S200) switch Friday.  It relies on VLAN1 for all of its "magic" and Smartport crap.  It only has L3 functionality for VLAN1.
I ended up removing it a replacing it with a 3650 and I was done in 10 minutes.
InayathUlla Sharieff
Me tooo like to join my best friend Leo on this.
VLAN 1 is by default and this cannot be deleted on any catalyst switch.
Bob Bagheri
As you can see from the other answers, you can't delete Vlan1.  Having said that, I was wondering what you are trying to achieve?  Or what is your concern?
Bob
chinpohpang851
VLAN 1 can not be deleted. What are you trying to achieve here?
Erjol Bane
you can disable it with the "shutdown" command
ardeaID
configure terminal
interface vlan 1
shutdown
end
copy running-config startup-config
