after Nexus 5548UP upgrade one interface stopped to work (Hardware failure)
from88
Level 4
Level 4
after upgrading switch from 7.0(5)N1(1)  to 7.1(4)N1(1) and then 7.3(8)N1(1). One interface changed the status to: Hardware failure
Tried to change the SFP modules, still the same, the swtich didn't even send (TX) light out. Is supposed the port is died. But is there any opinions on that ?
Have you had any experience on that ? Thanks
show interface ethernet 1/19
Ethernet1/19 is down (Hardware failure)
show interface status
Eth1/19 | FEX134B | faulty | 1 | full 10G | 10Gbase-SR
show interface ethernet 1/19 transceiver details
Ethernet1/19
transceiver is present
type is 10Gbase-SR
name is CISCO-FINISAR
part number is FTLX8571D3BNL-CS
revision is V03
serial number is FNS18061116
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 54.13 C 100.00 C -40.00 C 95.00 C -35.00 C
Voltage 3.09 V 3.50 V 2.90 V 3.45 V 2.95 V
Current 0.00 mA -- 25.00 mA 3.00 mA 24.00 mA 4.00 mA
Tx Power N/A -- 1.99 dBm -10.04 dBm 0.00 dBm -8.01 dBm
Rx Power -3.99 dBm 1.99 dBm -16.02 dBm 0.00 dBm -15.08 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
marce1000
 - You can run diagnostics on the module with : (presumably 'all' could be replaced by a specific module number)
show diagnostic result module all
  - You could also try to reset the module with :
5k# config t
5k-config# poweroff module x ( x=  Particular module)
5k-config# no poweron module x
 M.
thanks,
Seems, it indicates fail (letter F) on 1/19 interface:
    19) TestFrontPort :
   Eth     1   2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18  19  20
   Port --------------------------------------------------------------------------------
           .   .   .   .   .   .   .   .   .   .   .   .   .   .   .   .   .   .   F   .
   Eth    21  22  23  24  25  26  27  28  29  30  31  32
I assume i cant poweroff just one interface, it would shutdown all 32 interfaces, yes ? Sad, but I can't just poweroff the whole module with 32 interfaces.
            - Yep, the command is module-oriented and it will then imply all ports.
 M.
from88
Level 4
Level 4
thanks, as i understood it's the same as device reboot ?
