Switch C3750E. Power Supply bad, no input power.
My monitoring system is warning that a PS is in a "critical" state. I have 2 PS, one is "good" and the other "bad" according to the record below.
Current version 15.0 (2) SE2.
We already removed and put the powers back in the SW, the LEDs are normal as shown in the images provided.
We tested the energy and no electrical problems were identified.
Could upgrade to the recommended version fix this "false alarm" or is it recommended to replace them?
Is there a bug in this version related to powers supply?
If anyone can help, thank you.
Leo Laohoo
Could be a bug
I also think
Reza Sharifi
I have seen the same issue with 3850s. A software upgrade fixed it.
Hi, Reza.
Yes, I also saw this case, I will update IOS to the recommended version and pass on the results later.
Thanks.
