12-11-2025 12:00 AM
Hi if add to uplink switch
router bgp 65000
address-family ipv4 unicast
addreggate address 192.168.0.0/24
On all uplink Must be aggregate routes subnet 192.168.0.0/24 and only
One route announce to uplink 192.168.0.0./24
Announce to uplink all routes include this subnet
*>e192.168.0.0/24 172.18.14.250 0 64555 64556 i
*>e192.168.0.0/28 172.18.14.230 0 64555 65110 i
Cannot used prefix-list (only 24 permit )for my DDOS service work for /32
How can Aggregate that only announce supernet 192.168.0.0/24 to uplink ?
12-11-2025 12:05 AM - edited 12-11-2025 12:07 AM
Based on the information, i suggest below command :
router bgp 65000
aggregate-address 192.168.0.0 255.255.255.0 summary-only
check
show ip bgp neighbor x.x.x.x advertised-routes
you can refer to the document if needed :
12-11-2025 06:56 AM
If used aggregate 192.168.0.0/24 0.0.0.0
If used summary only next-hop of ip Learn still from bgp ? for example show ip route 192.168.0.0/24 172.18.20.74
12-11-2025 12:51 AM
You have three options:
1. use "summary-only" keyword when defining your aggregate, to advertise only the aggregate, however this aggregate will be advertised out to all your BGP neighbors
2. use a route-map out filter where you match on your aggregate, any other subnets within the aggregate and apply it in out direction to BGP neighbors you want this filter to be applied
3. use both the aggregate and the route-map filter, which is what I recommend
Here's the config sample:
ip prefix-list DENY_BGP_AGGREGATE_SUBNETS seq 5 permit 192.168.0.0/24 le 32
ip prefix-list PERMIT_BGP_AGGREGATE permit 192.168.0.0/24
route-map BGP_EGRESS_FILTER permit 10
match ip address prefix-list PERMIT_BGP_AGGREGATE
route-map BGP_EGRESS_FILTER deny 20
match ip address prefix-list DENY_BGP_AGGREGATE_SUBNETS
route-map BGP_EGRESS_FILTER permit 30
router bgp 100
aggregate-address 192.168.0.0/24 summary-only
neighbor x.x.x.x
route-map BGP_EGRESS_FILTER out
To your aggregate command you can also use the "attribute-map" keyword and attach a route-map where you set specific BGP attributes that your aggregate will be advertised with.
Cristian.
12-11-2025 12:53 AM
Hello admin@atrinnet.net ,
you need to add the summary-only in aggregate-address command
as it is explained here:
Hope to help
Giuseppe
