Aironet 1142 Console Unavailable
iphoneguru27
Hello all,
I am currently having difficulty configuring my AP. The Cisco Aironet 1142's that I bought from a working environment have been factory reset, and checked for issues throughly. That being said, I am unable to access the CLI from the console port, or through telnet. Whenever I try via telnet, I receive a 'no password set' error and termination. I've tried multiple cables, including the AIR-CONCAB1200 cable and a crossover cable from a friend, but had no luck. I would like to flash the image with an autonomous one, however I cannot even open a tftp session as I cannot get in. Has anyone else had this issue? Any help is greatly appreciated!
8 Replies 8
Peter Paluch
With a lightweight firmware, it is possible that the console is unresponsive. The method for reverting a lightweight AP to autonomous mode is described in these two documents:
https://web.archive.org/web/20090124191043/http://cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://reggle.wordpress.com/2013/01/12/converting-a-cisco-lightweight-access-point-to-standalone-mode/
Check these out!
Best regards,
Peter
I've tried the latter of the posts, but am confused. I've got the AP blinking red/orange now and that is in recovery mode. However, it won't bind to 10.0.0.1 so I can TFTP into it. I have the following configurations changed for my Router and Switch respectively.
Current configuration : 1149 bytes
version 12.3
service password-encryption
hostname CISCO_R1
boot-start-marker
boot-end-marker
enable secret 5 $1$xrBZ$QZ.v510UOZgYXANqBZI/r/
enable password 7 0822455D0A16
clock timezone CDT -6
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip dhcp excluded-address 10.0.0.1 10.0.0.4
ip dhcp pool DHCP_POOL
network 10.0.0.0 255.255.255.0
default-router 10.0.0.2
dns-server 10.0.0.2
domain-name ciscolab.local
interface Ethernet0/0
ip address 192.168.4.1 255.255.255.0
shutdown
full-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 10.0.0.2 255.255.255.0
full-duplex
ip default-gateway 10.0.0.2
ip http server
ip classless
Current configuration : 2127 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname CISCO_SW1
enable secret 5 $1$B9Ad$Wn9RObNmRPpXefwMZlUc01
enable password 7 060506324F41
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 10
duplex full
interface FastEthernet0/2
duplex full
interface FastEthernet0/3
duplex full
interface FastEthernet0/4
duplex full
interface FastEthernet0/5
duplex full
interface FastEthernet0/6
duplex full
interface FastEthernet0/7
duplex full
interface FastEthernet0/8
duplex full
interface FastEthernet0/9
switchport access vlan 20
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan20
ip address 10.0.0.3 255.255.255.0
no ip route-cache
ip http server
How do you know that the AP won't bind to 10.0.0.1? According to the documents, it will bind to this IP address on its own, without needing a DHCP server. The latter document mentioned that a static ARP may be needed on the TFTP server for the AP's IP/MAC because the AP did not respond to ARP requests.
Best regards,
Peter
Will try this later today. I am unfamiliar with creating a static ARP on a TFTP server, though. I recently changed my configuration files to bind to the 10.0.0.0/24 network. Could there be an issue with my configuration files?
Also I believe it isn't binding to 10.0.0.1 due to my nmap probes and the fact that the TFTP transmission times out
Starting Nmap 6.40 ( http://nmap.org ) at 2016-04-06 09:09 CDT
Nmap scan report for 10.0.0.2
Host is up (0.0017s latency).
Not shown: 998 closed ports
PORT STATE SERVICE
23/tcp open telnet
80/tcp open http
MAC Address: 00:30:85:9D:7F:41 (Cisco Systems)
Nmap scan report for 10.0.0.3
Host is up (0.0024s latency).
PORT STATE SERVICE
23/tcp open telnet
80/tcp open http
MAC Address: 00:1B:0D:78:AE:C0 (Cisco Systems)
Nmap scan report for 10.0.0.5
Host is up (0.000010s latency).
All 1000 scanned ports on 10.0.0.5 are closed
I have created a static arp using 'arp -s 10.0.0.1 MAC:ADDRESS' but to no avail.
I tried tonight and havent made any progress. So far I have power-cycled the AP, and gotten it into recovery mode (blinking red). I have it plugged into PoE and then into a switch, IP 10.0.0.3. The switch is plugged into a router IP 10.0.0.2. The AP is supposedly going to bind to 10.0.0.1, so I added the static arp. I have the IOS files ready to go. All thats left is that I still cannot connect to the AP. Should I just directly plug my computer into the AP, i.e. LAN port on PoE?
Edit: The TFTP server is on 10.0.0.5. I have a PC connected to the switch. I cannot ping the AP, or see it in any NMAP procedure.
Any ideas?
johnlloyd_13
Level 9
Level 9
hi,
what terminal emulation software did you use?
try using putty when connecting via console.
I have been using minicom on xubuntu. I have tried putty but it still doesn't respond for the access point. I have access to my Router and Switch with either minicom or putty, so the program isn't the issue.
