Alignment correction made at, problem.
CSCO11864939
I have a two cisco ISR 2811 routers with  "c2800nm-advipservicesk9-mz.151-2.GC2.bin" ios images. But i take a logs in below; How i solved this issue, please help me.
*Jul 18 10:32:33.255: %ALIGN-3-CORRECT: Alignment correction made at 0x401A9168z  reading 0x3F5D7EB9
*Jul 18 10:32:33.255: %ALIGN-3-TRACE: -Traceback= 0x401A9168z 0x402CB65Cz 0x402CB8D4z 0x40070D04z 0x4284979Cz 0x426D8FC8z 0xFFFF0360z 0xFFFF0360z
*Jul 18 10:32:33.255: %ALIGN-3-CORRECT: Alignment correction made at 0x401A74E0z  reading 0x3F5D7EB9
*Jul 18 10:32:33.255: %ALIGN-3-TRACE: -Traceback= 0x401A74E0z 0x401A9230z 0x402CB65Cz 0x402CB8D4z 0x40070D04z 0x4284979Cz 0x426D8FC8z 0xFFFF0360z
*Jul 18 10:32:33.255: %ALIGN-3-CORRECT: Alignment correction made at 0x401A9168z  reading 0x3F60F439
*Jul 18 10:32:33.255: %ALIGN-3-TRACE: -Traceback= 0x401A9168z 0x402CB65Cz 0x402CB8D4z 0x40070D04z 0x4284AE7Cz 0xFFFF0360z 0xFFFF0360z 0xFFFF0360z
*Jul 18 10:32:33.255: %ALIGN-3-CORRECT: Alignment correction made at 0x401A74E0z  reading 0x3F60F439
*Jul 18 10:32:33.255: %ALIGN-3-TRACE: -Traceback= 0x401A74E0z 0x401A9230z 0x402CB65Cz 0x402CB8D4z 0x40070D04z 0x4284AE7Cz 0xFFFF0360z 0xFFFF0360z
Thanks.
Peter Paluch
Servet,
These messages are caused by a software defect in your IOS. It is not causing any incorrect operation but it does access memory in an ineffective way (multiple accesses to RAM in order to read or write a single value that could otherwise have been handled in a single memory access). The only way of solving this issue is to change to a different IOS version where this ineffectivity has been corrected by IOS software engineers.
You are running 15.1(2)GC2 which is itself based on 15.1T IOS train. This train is considered a development train where potential bugs or issues may arise with greater probability. I suggest either looking for an updated GC revision if any is available, or if possible, moving away to a stable release, either 15.0M or 15.2M.
Best regards,
Peter
Peter Paluch
Servet,
Best regards,
Peter
CSCO11864939
Peter,
Thank you for your interest, when i was a made to above then my issue were solved.
