Allow DHCP and deny ICMP ACL
QTortellini
EDIT: THE SWITCH PASSWORD IS Cisco
Hi people, I've been struggling with this problem all day.
So I got 3 VLANs
VLAN 10: 192.168.10.0/24
VLAN 20: 192.168.20.0/24
VLAN 30: 192.168.30.0/24
Now I have a DHCP server on VLAN 10 and I need VLAN 20 to be able to communicate fully with VLAN 10 and 30 and block the communications between VLAN 30 and 10 except for DHCP. I'll leave my infrastructure here so you guys and girls can take a look at it. I've been trying to use
access-list 100 permit udp any any eq 67
access-list 100 permit udp any any eq 68
access-list 100 deny 192.168.30.0 0.0.0.255 192.168.10.0 0.0.0.255
as an IN acl to no avail because the moment I type the last line I lose comms between VLAN 10 and 20. Hope you guys can give me a hand. Cheers!
Reza Sharifi
Try this config:
access-list 100 permit udp any any eq bootps
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip any any
access-list 101 permit udp any any eq bootpc
access-list 101 permit ip any any
interface vlan 10
ip access-group 100 in
ip access-group 101 out
Reza Sharifi
Try this config:
interface vlan 10
Thank you. I replaced the third line with "access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255" and it worked like a charm.
Glad to know it is all working for you!
