Allow only specific vendor mac and block others.
vinod.mali
Hi Guys,
I have arequirement where in I need to allow only specific vendor made desktops/laptops to be connected to the switch and block the rest.
Say I want only the HP made Laptops to be connected on the Network. and block all other vendors. such as dell, ibm etc.
I am having Catalyst 4500 switches in My network.
i tried using the mac access list using the permit and deny statement and then mapping the access list to the vlan access map and then filter using the vlan id.
But this doesnt work on cat 4500....the same I tested for 2950 switch and it works perfectly.
are there any restrictions on 4500 or any extra configuration has to be done.
If not is there any other way out to achieve this.
Sandeep Choudhary
HI Vinod,
it won't work this way because mac acls only match non ip traffic.
You may ry to use class map(MCQ).
example:
Let's suppose you want only to permit 3 MAC addresses and deny all others
class-map match-any HPLaptop
match source-address mac xxxx.xxx.xxxx
match source-address mac yyy.yyy.yyy.yyy
match source-address mac zzz.zzz.zzz.zzz
class-map match-any DELL
match not class-map HPLaptop
match http host DELL
Hope it helps.
Hi Sandeep,
In class Map I have the option of matching the access-group... I  dont find any option to match source-address or any Mac address.
switch1(config-cmap)#match ?
  access-group  Access group
  any           Any packets
  application   Application to match
  cos           IEEE 802.1Q/ISL class of service/user priority values
  dscp          Match DSCP in IPv4 and IPv6 packets
  ip            IP specific values
  metadata      Metadata to match
  precedence    Match Precedence in IPv4 and IPv6 packets
  protocol      Protocol
  qos-group     Qos-group
