Router TFTP issue PLEASE HELP!!!!
Justin Bray
I recently lost my ios when trying to upgrade it. I have a 2612. In rommon I entered the ip addresses and file name and when I use tftpdnld -r it appears to not be reaching my pc as for it is only coming up with dot and then timing out. My pc is set to the correct ip and I am using cisco tftp 1.1. I have the routers eth0/0 connected to pc with a crossover cable. Please help I am in the proccess of learning for my first cisco cert and this has put a halt on things.
Bilal Nawaz
Are you able to ping? Also please ensure Windows FW is off if you are using a windows machine, or any other OS for that matter.
Folow the DOC Jan has provided.
hth
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Jan Rolny
Level 3
Level 3
Hi Justin,
please check this document to recover your image.
https://supportforums.cisco.com/docs/DOC-2340
HTH,
Jan
Bilal Nawaz
hth
Hello
Just like to add to what others have posted:
Once you have applied the tftpdnld config follow it by SET command to save your changes
Would also make sure that you pic nic is set to auto negotiate
As for pinging the tftp server ( ie the windows pic) from rommon,Not sure this can be done, as the routers interface is only initialised when you initiate the tftpdnld command. ( I could be wrong though!)
Res
Paul
Kind Regards
Paul
Justin Bray
Thank you so much for the help after I turned the firewall off it send it through just fine.
