Allowing NAT isakmp port 500
liamr44
Hi All
Hoping you can help with an issue we have with Catalyst 9300
I am trying to SNAT traffic from our inside interface to our outside interface GigabitEthernet1/0/10
ip nat inside source list 1 interface GigabitEthernet1/0/10 overload
ip access-list standard 1
10 permit (source address)x.x.x.x log
When looking at ip nat translations I can see NAT is working for tcp and udp traffic. But not for isakmp port 500 or 4500
nothing appearing in the logs
Would we need additional commands to allow NAT to work on port 500 or 4500?
I have also tried
ip nat inside source static udp x.x.x.x 500 x.x.x.x 500 extendable
and
ip nat inside source static udp x.x.x.x 4500 x.x.x.x 4500 extendable
note - we are not terminating any ipsec connection on the device just passing through
Many Thanks
Liam
You add staitc pat,
Do you check
Show ip nat translation
Do you see Udp 500 and udp 4500?
Hi Thanks for the reply
We have tried adding a static nat
ip nat inside source static x.x.x.x(source address) x.x.x.x(global address)
I can see the following in ip nat translations, and NAT is working for tcp packets, icmp and udp when testing on ncat but still wont NAT port 500 or 4500
Pro Inside global                          Inside local                     Outside local         Outside global
--- x.x.x.x(global address)          x.x.x.x(local address)          ---                   ---
I think the IPsec config wrong and that why the NAT not work.
can I see IPsec config of both side
