Allowing port 3389
eddiebrown1986
Hello Fellow Cisco Professionals,
I am looking to grant public access to a private RDP server via RD gateway. Now I have set up the front end of this server but am having difficulties in deciding what I should do about the backend access. I have an 891 Cisco router that is apart of a router on a stick configuration. Right now it is using NAT overloading from the inside to the outside. Along side of a static default route we are able to gain access to the public world.
Here is the configuration for this:
end
Now is the best way to do this using an access list? Or a new NAT command with a preference of my external being translated to my interal private IP? Or a combination of the both?
If I add a new NAT preference point my external address to my internal server address would that compromise the functionality of my network?
Any insight would be appreciated on this.
Eddie
2 Accepted Solutions
Kelvin Willacey
Level 4
Level 4
A static NAT should work fine and if you know the public IP of the sources that are trying to connect then you can restrict it, otherwise a VPN might be better if your router supports it.
Yes it will still work with your existing IP address, you will just need to do a static PAT.
6 Replies 6
Kelvin Willacey
Level 4
Level 4
Hey Eddie, remove your public IP and passwords. You may want to change your password at this point.
These are old configs with old IP addresses, nothing to worry about.
Kelvin Willacey
Level 4
Level 4
What if I want to reuse my public IP address that is assigned to my outside interface? Is that possible or do I need to purchase a second IP address?
Ok so I have set up the static NAT to route all incoming traffic on port 443, 80, and 3389 to my inside private address.
I have also opened up ports 443, 80, and 3389 via access list 101. I have applied 101 to my outside interface heading in the inbound direction. I have also enabled CBAC on all interfaces to inspect both inbound and outbound. I am still unable to get to my RDWEB page hosted by my rdconnection server.
This is my current configuration:
service password-encryption
hostname ROLIAJ01
boot-start-marker
boot-end-marker
enable secret 4 avq1sKoPiePO9fyYwxoCGtXKX9/uitvC9ih8omI4b1.
no aaa new-model
clock timezone utc 2 0
no ipv6 cef
ip source-route
ip cef
ip inspect name GMRA tcp router-traffic
ip inspect name GMRA udp router-traffic
ip inspect name GMRA icmp router-traffic
license udi pid CISCO1941/K9 sn FGL161920AW
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description External Interface
ip address 81.x.x.x 255.255.255.252
ip access-group 101 in
ip nat outside
ip inspect GMRA in
ip inspect GMRA out
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Interface
no ip address
ip nat inside
ip inspect GMRA in
ip inspect GMRA out
duplex auto
speed auto
interface GigabitEthernet0/1.20
description Vlan20 Trunk
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.10.10.1 255.255.255.128
interface GigabitEthernet0/1.99
description Vlan99 Trunk
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool GMRA 81.x.x.x 81.x.x.x prefix-length 30
ip nat source static tcp 192.168.20.37 80 81.x.x.x 80 extendable
ip nat source static tcp 192.168.20.37 443 81.x.x.x 443 extendable
ip nat source static udp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip nat inside source list 7 pool GMRA overload
ip nat inside source static tcp 192.168.20.37 3389 81.x.x.x 3389 extendable
ip route 0.0.0.0 0.0.0.0 81.x.x.x
access-list 7 permit 192.168.20.0 0.0.0.255
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 3389
Now I am positive I have done everything properly on the server side. I did a "sheilds up!" test on my external IP anddress and even with my access list applied to the outside interface pointing in. "Sheilds Up!" is reporting port 443 and 80 both as closed.
If anyone see's anyhting wrong on my configs can you please highlight.
Eddie
