Alternate IP Addresses
daniel.bowen
Hi All,
Strange problem. I have a L3 switch that has an IP link to another switch with a primary and an alternate IP address.
When I ping off of that switch, the first hop shows as follows:
1 10.52.252.58 0 msec primary add
10.52.252.57 0 msec alt address
10.52.252.58 4 msec primary add
2 10.52.252.18 0 msec 0 msec 0 msec
Any idea why it bounces between the two?
Cheers,
Dan
mmandel
Check your routing table. What routing protocol are you using?
Check the route metrics for the the primary and secondary IP address on the switches, and anything in between.
There is nothing inbetween.
The routing protocol is OSPF and the metric to both addresses is 0.
Cheers,
Dan
hi dan
can you post the config here and also the output of show ip route ?
regds
