alternate to subinterface
Network Pro
Level 7
Level 7
hi
i understand that you cant create vlan subinterface on 3750 or 3550
switch(config)#int gi1/0/52.100
% Invalid input detected at '^' marker.
Is there any alternative to create the above (by upgrading to latest ios?). basically i have a trunk port with SVI interfaces but i would like to spilit the trunk into sub interfaces and have it on its own vlan AND have the layer 3 ip for some  (like below)
switch(config-if)# switch access vlan 100
switch(config)#int gi1/0/52.200
switch(config-if)# switch access vlan 200
switch(config)#int gi1/0/52.300
switch(config-if)# no switchport
switch(config-if)# ip address 10.10.30.1 255.255.255.0
int vlan 100
ip address 10.10.100.1 255.255.255.0
int vlan 200
ip address 10.10.200.1 255.255.255.0
is the above possible ?
thanks
5 Replies 5
Abzal
Level 11
Level 11
What is your purpose for that? What do you want to reach?
For such thing you need router in order to create subinterfaces.
Hope it will help
Best regards,
Abzal
i would like to spilit my vlans for troubleshooting. for instance i can just shutdown just 1 vlan instead of shutting down the entire trunk port ?
You can shut down a vlan from vlan config mode without going through this. I've never done it, but it sounds like this is what you're wanting.
DR_Switch(config)#vlan 282
DR_Switch(config-vlan)#?
VLAN configuration commands:
  are           Maximum number of All Route Explorer hops for this VLAN (or
                zero if none specified)
  backupcrf     Backup CRF mode of the VLAN
  bridge        Bridging characteristics of the VLAN
  exit          Apply changes, bump revision number, and exit mode
  media         Media type of the VLAN
  mtu           VLAN Maximum Transmission Unit
  name          Ascii name of the VLAN
  no            Negate a command or set its defaults
  parent        ID number of the Parent VLAN of FDDI or Token Ring type VLANs
  private-vlan  Configure a private VLAN
  remote-span   Configure as Remote SPAN VLAN
  ring          Ring number of FDDI or Token Ring type VLANs
  said          IEEE 802.10 SAID
  shutdown      Shutdown VLAN switching
  state         Operational state of the VLAN
HTH,
John
HTH, John *** Please rate all useful posts ***
Kevin Dorrell
Level 11
Level 11
Unfortunately you cannot do that on a switch.  Instead, you have to run a trunk and a bunch of SVIs, as you have done.
Unfortunately, if you are running any routing protocols through the trunk, and the trunk link fails, then the re-convergence is slower because it has to rely on dead times rather than detecting link-down.
Kevin Dorrell
Luxembourg
say if i introduce to bring in a router and do
on router:
int fa0/0.20
encapsulation dot1q 20
ip address 192.168.2.254 255.255.255.0
no shut
int fa0/0.30
encapsulation dot1q 30
ip address 192.168.3.254 255.255.255.0
no shut
on the switch:
vlan database
vlan 20 name 20
vlan 30 name 30
int vlan 20
ip address 192.168.2.200 255.255.255.0
no shut
int vlan 30
ip address 192.168.3.200 255.255.255.0
no shut
I know the above will work for L2 vlans but for Layer 3 (without any vlans will the below config do ?)
int fa0/0.40
ip address 192.168.4.1 255.255.255.0
no shut
int fa0/0.50
ip address 192.168.5.1 255.255.255.0
no shut
on switch side (different switch to the one above)
int fa0/1
ip add 192.168.4.2 255.255.255.0
no shut
int fa0/2
ip add 192.168.5.2 255.255.255.0
no shut
Basically my question is if i replace the l3 switch with a router can i use one port for L2 sub interface and another port for L3 sub interface as above ?
if so how do i create a layer 3 sub interface ?
