Alternater for Cisco 877-K9-Sec Router
Now the Cisco 877 Series routers are EOL & We need the alternate in the same price range.
Sandireddy
paolo bevilacqua
Consult your Cisco reseller.
Reseller is finding that, but right now the Cisco Manager who takes care of our acct. is in leave. So just because of getting some idea idea I am posting this.
How many VLANs are you planning to use?
The 860 supports only 2 VLANs (like the 870 running 12.4 and 15.0 IOS);
The 880 suppport up to 8 VLANs; and
The 890 supports up to 14 VLANs
The 860 and the 880 has a 4-port, Layer-2 switch port while the 890 has an 8-port Layer 2 switch port.  All switch ports are FastEthernet only.
The 870, depending can on the IOS you are running can support 2 or 10 VLANs.
