Any advantage to enabling performance mode on 25% utilized WS-X6904-40G-2TXL?
jameswilson1
I'm going to have a x6904 card with only two 10G ports in use initially.  I don't plan on oversubscribing the card, but would like to leave the option open in the future in case it becomes needed.  Assuming that you only use two enabled ports per ASIC, does the card perform any different in performance mode vs. oversubscription mode i.e. is there any reason why you would want to enable performance mode and lock out the future possibility of oversubscribing when needed?
InayathUlla Sharieff
Cisco Catalyst 6900 Series 4-port 40 Gigabit Ethernet Fiber Module can operate in a number of modes. Performance mode enables 80 Gigabit Ethernet performance by using two ports without oversubscription. In Oversubscribed mode, the module uses four ports with 2:1 oversubscription. Details are as follows:
   40 Gigabit Ethernet Oversubscribed mode (default)
     Four 40 Gigabit Ethernet ports using CFP transceivers.
     Ports are numbered as interface FortyGigabitEthernetslot#/1-4 (Figure 1).
     The interface range command is allowed.
   10 Gigabit Ethernet Oversubscribed mode
     16 10 Gigabit Ethernet ports using FourX adapters.
     Each FourX adapter has 4 SFP+ transceivers.
     Ports will be numbered as interface TenGigabitEthernetslot#/5-20 (Figure 2).
   Mixed 10/40 Gigabit Ethernet mode
     One-half of the module uses two CFP transceivers for 2 x 40 Gigabit Ethernet ports, while the other half uses two FourX adapters for 8 x 10 Gigabit Ethernet ports.
     Depending on which side has the 40 Gigabit Ethernet ports, port numbering is as follows:
   40 Gigabit Ethernet ports on left: Interface FortyGigabitEthernet slot#/1-2 and interface              TenGigabitEthernetslot#/13-20.
   40 Gigabit Ethernet ports on right: InterfaceTenGigabitEthernetslot#/5-12 and interface              FortyGigabitEthernetslot#/3-4.
   Performance mode (Figure 3)
     Note that Oversubscribed mode is the default setting.
     In 40 Gigabit Ethernet Performance mode, ports 1 and 3 will be active.
     In 10 Gigabit Ethernet Performance mode, ports 5-8 and 13-16 will be active.
     The command-line interface (CLI) is required to change modes. Check release notes for details.
     The mode can be changed per port group.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unsure if applies to that particular card, but performance mode often seems to allocate more buffers to the enabled ports.  This can help avoid drops with bursty traffic.
