4500x Dual Active Detection with LACP
Mokhalil82
Level 4
Level 4
Hi Guys
I have configured 2 4500x switches as a vss pair and vss is working fine. These will be connected to 2 stacks of 3750x switches with each stack having 2 switches.
                                 4500x
         3750x Stack1                 3750xStack2
From SwitchPort NoChannel GroupTo SwitchPort NoChannel GroupMedia TypeComment
3750X Stack1Ten 1/1/114500X Ten 1/1/1110Gb SPF+3750X TO 4500X Interlinks
3750X Stack1Ten 2/1/114500X Ten 2/1/1110Gb SPF+3750X TO 4500X Interlinks
3750X Stack2Ten 1/1/124500X Ten 1/1/2210Gb SPF+3750X TO 4500X Interlinks
3750X Stack2Ten 2/1/124500X Ten 2/1/2210Gb SPF+3750X TO 4500X Interlinks
4500xTen1/1/14 4500xTen1/1/14 10Gb SFP+Dual-Active-Detection
4500xTen1/1/15 4500xTen1/1/15 10Gb SPF+VSL Link
4500xTen1/1/16 4500xTen1/1/16 10Gb SPF+VSL Link
The ports will be connected as above. From each stack there are 2 uplinks, 1 to each of the 4500x but virtually to the same 4500x as they are a virtual pair.
I have't configured the uplinks yet as im trying to get the dual active detection done first, in the config on the 4500x it does not give me the option for fast-hellos, it only list pagp
Switch(config-vs-domain)#dual-active detection ?
  pagp  Dual-active detection using PAgP
Anyone know why this may be
Parminder Nath
As per configuration guide for this platform we do have enhanced pagp only as dual active detection mechanism;
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html#wp1063718
Parminder
Thanks Parminder
I found that the IOS i was using did not support dual active detection with lacp. Ive just upgraded to version 3.5.3 and the option for fast hello is now there
Thanks again
