Any replacement for these 2 commands line?
s8709251h
Hi All Experts,
I have problem in keying these 2 command line into a cisco 1921 router, are there others command to replace these 2 command?
1) ip inspect name inspect-out cuseeme timeout 3600
2) snmp-server enable traps entity-sensor threshold
cadet alain
Support for the CU-SeeMe protocol and the cuseeme keyword was removed beginning  from 15.1(1)T
I don't know about the second one.
Alain
