09-29-2015 11:14 PM - edited 03-08-2019 02:00 AM
I am planing to propose DMVPN solution to one of my customer through my L2/L3 MPLS. There One Hub site and 500 Spoke sites. I will control bandwidth of all Spoke sites to 2MB (more than enough), and 1G to Hub site. So I think there is no bandwidth concern. For some budget limitation, all Spoke sites will be Cisco-881-SEC-K9.
So please kindly let me know some idea what will be suitable for Hub site.
Many Thanks,
09-29-2015 11:37 PM
Hello
For this scenario, personally I would go for one of the Cisco ASR 1000 series aggregation routers for the Hub location. For example the 1001 or 1001-x depending on how many interfaces you require and if there's a need for 10G interfaces.
Hope this helps.
Best regards,
Martin
09-30-2015 12:18 AM
Thanks a lot Martin Hruby. I will choose ASR 1001-X without 10G. Because Hub site`s upstream MPLS Pre-aggregation router can provide only 1G. Now It is right inside permitted budget plan. :)
09-30-2015 05:44 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I too would lean toward an entry ASR 1K, but the ISR 44xx series, especially the 4451, might be suitable too.
09-30-2015 08:00 PM
Thanks Joseph.
Let me check.
