Any way to test TCP port from IOS?
news2010a
Level 3
Level 3
Folks, from a Windows PC I can do "telnet IP 80" in order to test TCP port status on target host.
Any similar command in IOS?
5 Replies 5
Jon Marshall
Marlon
router# telnet 80
if you do
router# telnet ?
then you will see all possible ports you can telnet to.
Jon
Sorry for the stupid question. I did the below and concluded too quickly that it did not work. I turned out that instead of saying the port was not open, the IOSgave me a message which I thought it was ignoring my command.
2600#telnet 10.155.206.5 80
Trying 10.155.206.5, 80 ...
% Destination unreachable; gateway or host down
Sending 5, 100-byte ICMP Echos to 10.155.206.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Are you sure there is a webserver up and running on 10.155.206.5 ?
Jon
It is; but it turned out that I found ACL's blocking the traffic to the webserver. Hence the output I did not undestand initially from the IOS command.
Okay, so it works fine then ?
Jon
