Anycast RP and OSPF load balancing
jsdurstjsdurst
Hi.  I'd appreciate any information or experience you may have in the following scenario.
If you have 3 Anycast RPs that have an equal routing metric from a host that wishes to join a multicast source, how does OSPF load balancing impact this solution?  It seems to me that the load balancing, especially if it is per-packet, could cause problems.  Or will MSDP take care of this and it is a non-issue?
What are your thoughts or experiences?
Thank you!
0 Replies 0
