QOS is not working on 2960 switch
vishal agavane
We have layer-2 network of 2960 & 4500 switches (2960 --Trunk---4500 ---Trunk---2960), we have marked COS/DSCP value at 2960 access switch as EF even thought QOS is not working. we cant see packets hits to ACL and policy-map as well.
Our configuration is as follow.
access-list 101 permit ip any any
Class-map Test
match access-group 101
policy-map Test
class Test
set DSCP EF
Attached above policy to end user port
Interface G1/0/2
service-policy input Test
Please suggest.
9 Replies 9
Julio E. Moisa
Could you please share the following output
show policy-map interface g1/0/2
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Please find below output..
2960-Switch#sh policy-map interface gi 1/0/2
 GigabitEthernet1/0/2 (End user connected port)
  Service-policy input: DLP
    Class-map: DL (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name TEST
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
ZOR-98B09A-AS#
We have TEST ACL (permit ip any any)
Hello
Does the 4550 have qos enabled - if so it will remark the packet if not trusted on its trunks between the 2960's
res
Paul
Kind Regards
Paul
Hi Paul,
For testing purpose we have connected 2960 switch back to back through trunk port and configured QOS. MLS QOS is enabled globally.
We were tested QOS with 4500 switches by connecting them back to back and found it was working fine, QOS configuration on 4500.
Class-map Test match-any
match access-group Test
Policy-map Test
class Test
set cos 5
Class-map IMP
match cos 5
policy-map IMP
class IMP
priority
Access Port :- service-policy input Test
Uplink interface --- service-policy out IMP
I can't attached service-policy in output direction in 2960 switch? and i cant see any priority option under policy-map available in 2960 switches? can you please help me to understand how 2960 will priorities COS/DSCP mark traffic? do we have to configure any setting/configuration on Trunk port to get cos/dscp mark traffic on priority.
Now Layer-2 QOS seems working fine.
I have enabled MLS QOS globally and assigned Priority-Queue out on uplink interface with Class-map and policy map which marked access port traffic with DSCP "EF"
Now only problem with me is i cant see anywhere that QOS is matching policy-map or ACS getting hit, etc.
Can you please let me know how to check that configured QOS is working? any commands which help me to see working QOS? as far as i remember with other cisco switches i could see ACL getting hitted and policy-map also showing matched packets but in Layer-2 switch i can't see any one of them.
Hello
On the receiving switch you can capture the traffic for that specific marked class.
class-map DSCP_cm
match ip DSCP EF
policy-map DHCP_pm
class DSCP_cm
in x/x
service-policy input DHCP_pm
sh policy-map interface x/x
res
Paul
Kind Regards
Paul
We have tried that but unable to get anything, however QOS working fine.
      0 packets, 0 bytes
      0 packets, 0 bytes
      Match: any
AS#
Hello
on the switches-
sh mls qos maps cos-dscp
Make sure the dscp markings your capturing match to the cos value you have classified the traffic with and amend your class-map accordingly?
Lasty - How are you generating the traffic to capture?
res
Paul
Kind Regards
Paul
Joseph W. Doherty
On a 2960, you generally won't see hits on a QoS policy as you would on a router.
You need to look at the QoS stats on the ASICs.
There's commands for that, but I don't recall what they are off-the-top-of-my-head.
