Anyconnect setup using ASDM
Mokhalil82
Level 4
Level 4
Pretty new to this so there may be a simple answer to this.
A customer uses the cisco VPN client and uses an LDAP server for authentication. They have asked for an anyconnect VPN to be setup just for their Win 8 users as the Win 8 users have issues using the VPN client.
We have purchased the anyconnect licenses for the asa 5520x
My question is Can I configure a new SSL anyconnect VPN using ASDM and use the existing configured VPN Pool and LDAP Server. Just trying to find a simple way of doing this.
Also when the customer tries to login, they are only presented with a username and password screen, how do they enter their pin from the authentication token they also use
yes , you can just use asdm vpn wizard/ASDM Assistant, there u can specify which AAA server groups and protocol in your case is LDAP  to use .
Thanks for your response.
I now get to the login page which asks for username and password when I https to the address. The customer uses vasco tokens for 2 factor authentication. How do I integrate this into anyconnect so that the login asks for username, password and token number
