Anyone got WS-C2960-8TC-L (k9) firmware ?
davidnghk
I am new to Cisco.
just bough a second hand Cisco Catalyst 2960-8TC-L
model: WS-C2960-8TC-L
#show Version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)Technical Support: http://www.cisco.com/techsupportCopyright (c) 1986-2010 by Cisco Systems, Inc.Compiled Wed 21-Apr-10 05:52 by prod_rel_teamImage text-base: 0x00003000, data-base: 0x01400000
ROM: Bootstrap program is C2960 boot loaderBOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
System returned to ROM by power-onSystem image file is "flash:c2960-lanbase-mz.122-53.SE2.bin"
Model revision number           : A0Motherboard revision number     : C0Model number                    : WS-C2960-8TC-L
Version ID                      : V01Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image------ ----- -----              ----------            ----------*    1 9     WS-C2960-8TC-L     12.2(53)SE2           C2960-LANBASE-M
Configuration register is 0xF
I run below command, but it generated an error.
I search the internet, it said my firmware does not contain k9 in it, so it does not have the http function.
conf t
ip http secure-server
I try to find the firmware on cisco website, just can't seems to find it.
could someone kind enough to send me the above switch firmware that contain the k9 ?
any "SW Version" will do. (best would be c2960-lanbasek9-mz.122-46.SE.bin)
please zip it or tar it or md5 it.
thank you so much.
Leo Laohoo
2960 firmware can be downloaded from:  12.5(55)SE12 or 15.0(2)SE11
9 Replies 9
sorry I thought its 2960C.
your best best of to google it, you might find if someone shared privately, if you find there would be no way to verify actual Cisco hash for the image so it would be risky.
-hope this helps-
Leo Laohoo
wait, is that mean "8 port switch" share the same firmware with "24 port switch"?
Yes, they do.
davidnghk
I just flash the 24 port firmware to a 8 port switch, and it is working.
I flash this one c2960-lanbasek9-mz.122-46.SE.bin
I hope this switch is deployed in an air-gapped network.
why say that? because it is too old and have vulnerability?
Exactly.
