Anyway to have different speed ports in a LACP group
I am trying to setup a LACP group to connect an Aruba AP575 outdoor access point.   On the AP575 the primary ethernet port is capable of 2.5 Gbps and the secondary ethernet port is capable of 1Gbps.   The AP575 supports an LACP to give net effective bandwidth of 3.6 Gbps, and I also would like this for fault tolerance.    Is there any way to support this on a C9300-48UXM switch?    Form everything I have read it seams the answer is no, but I thought I would ask.
Thx
Bryan
Leo Laohoo
Not possible.
Mohsin Alam
LACP needs same duplex/speed settings on both ends.
## Make sure to mark post as helpful, If it resolved your issue. ##
balaji.bandi
All LAN ports on a port channel must be the same speed and must all be configured as either Layer 2 or Layer 3 LAN ports.
BB
Thank you to all who answered!
