AP-1552H Antennas
samalimostufa
Dear Technical Experts,
I need your support regarding the following :
the customer owns 1552h access points and need to buy antennas for them ,
the problem that our country regulations don't allow any antennas gain exceed 6 dBi to operate in both frequencies 2.4 GHz and 5 GHz , Thus neither AIR-ANT2547V-N= nor AIR-ANT2588P3M-N can be quoted , I need your support to check if there any alternative can be compatible with 1552H from your experience like AIR-ANT2450V-N= as the customer agrees the single band option ,,
please advise..
Thanks ,
Samah
on a side note, and in addition to Julio's post, I would have a look at third party (non-Cisco) antennas. The link below lists a few that all have a gain of 6DB for both 2.4 and 5 GHZ...
http://www.terra-wave.com/shop/wifi-antennas-dual-band-outdoor-omnidirectional-wifi-antennas-c-33_86.html?osCsid=dkcmofusuqjoef3m6qovsu94d5
Based on the following link the AIR-ANT2450V-N antennas are not supported, I suggest contact to an authorized Cisco vendor in order to get an accurate answer.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1550-series/data_sheet_c78-719520.html
Please check this link as well:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Dears,
What is the limitation on AIR-ANT2450V-N as they share the same connector type,
What should I check to decide if the antenna is compatible with the access point or not ?
the customer don't accept a third party  antennas :(
Samah
If your customer doesn't accep third party antennas, your only option is to operate the Cisco antenna at 2.4Ghz (4db gain). Is that an option ?
