AP 2802 are not joining cisco 3650 WLC
claude.karemera
hello,
AP 2802 are not joining cisco 3650 WLC:
here are the message am getting from the switch:
CAPWAP-3-DISC_UNSUPPORTED_AP: 1 wcm:  Rejecting discovery request from unsupported AP
Please help!
5 Replies 5
most likely you have a compatibility mismatch. Check the link below:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
hi Georg,
from the datasheets.... WLC 3650 can control AP 2802... please the SW version from both devices:
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PD 03.06.06E cat3k_caa-universalk9 INSTALL
AP Running Image : 8.3.143.0
Primary Boot Image : 8.3.143.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Base ethernet MAC Address : 6C:8B:D3:16:FB:FA
Part Number : 73-100821-03
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC23102WKP
Top Assembly Part Number : 068-100739-01
Top Assembly Serial Number : FDW2116B4BH
Top Revision Number : A0
Product/Model Number : AIR-AP2802I-E-K9
Post the complete output to the command "sh version".
Maybe the AP is running ME firmware?
AP 2802 can be supported by WLC 3650 but you have to check with which sw version of the WLC. Sometimes after an sw WLC upgrade the AP is no more supported
Hello
Does the AP have lightweight (K9W8) or autonomous (K9W7) mode software, For it to joining a WLC it needs to be a lightweight so support CAPWAP.
show version
Kind Regards
Paul
