AP1562I AP keeps disabling radios Using 3850UPOE
andrew_cooper
Hello,  I have a AIR-AP1562I-B-K9 that keeps turning the radio off and I believe it is power related but not sure why.  I am using a 3850 UPOE switch with 60w power capability.
sh power inline on the switch shows the AP pulling 39.1 watts.
Bouncing the port will bring reboot the AP and it will come back online, radios on, etc.  But it will disable the radios again usually within an hour or so.
From the WLC I am seeing the below
Attributes for Slot 0
Radio Type................................... RADIO_TYPE_80211n-2.4
Administrative State ........................ ADMIN_ENABLED
Operation State ............................. DOWN
Operation State Down Cause................... Radio reset due to (41) inline CDP low power mode holddown
Operation State Down Code.................... RADIO_RC_EXIT_LOW_PWR
Mesh Radio Role ............................. ACCESS
Radio Role .................................. Client Serving (Local)
CellId ...................................... 0
Any help would be greatly appreciated.  Thanks!
15 Replies 15
@Eric Hansen wrote:
I know that its been a long time, but did you ever find a solution to this problem?
Create a new thread.
