AP801 looses the configuration after power outage.
achyut.chalise
I have Cisco881W router, I configured router and AP801 but some reason AP looses the configuration after power outage. Config-reg setup to 0xf to AP 801 ?
How do I change the Config-register on AP801 ?
Thank you,
Achyut
Share me show version of your AP801
Sandy
Thank you for promp reply, here is brief of the show version
ap801>show version
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 15.2.4-JA1, RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
config-register 0xF
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 15.2(4)JA1, RELEASE S        OFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:57 by prod_rel_team
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(10b)JDA3, RELEASE SOFTWAR        E (fc1)
ap uptime is 19 hours, 13 minutes
System image file is "flash:/ap801-k9w7-mx.152-4.JA1/ap801-k9w7-mx.152-4.JA1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP801GN-A-K9 (PowerPC 8343) processor (revision C0) with 49142K/16384K bytes of memory.
Processor board ID FTX1433822Q
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F8:66:F2:AB:45:94
Part Number                          : 73-11027-07
PCA Assembly Number                  : 800-28807-07
PCA Revision Number                  : B0
PCB Serial Number                    : FOC142949ET
Top Assembly Part Number             : 800-29556-04
Top Assembly Serial Number           : FTX1453822Q
Top Revision Number                  : B0
Product/Model Number                 : AP801GN-A-K9
Configuration register is 0xF
Thanks I figured it out..
AP was in unified boot image. I Cahnge to autonomous mode.
