Archive configurations
cisco_lite
I would like to archive configurations on Cat 6500.
Is it fine to archive configuration to sup-bootdisk or sup-bootflash. Could you please tell me the difference between bootdisk and bootflash.
Edison Ortiz
They are both file systems in the 6500, the sup-bootflash is often seen in the system when you have the 64MB bootflash device.
If you see the bootdisk available as a file system, you have the Compact Flash Adapter that holds 512MB.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/sup720.html#wp1053703
HTH,
__
Edison.
