Arista trunk to Cisco 3850 not working
chabot-isaac
I have an Arista DCS-7050TX-64 and Cisco Switch 3850 24X UPOE and a simple trunk configuration does not work.
Port light is steady green and recognizes when port is shutdown so not Layer 1 problem, but more than that, there's nothing happening.
When in routed port, does not work also, so if I'm correct that means Layer 2 is problematic.
LLDP doesnt show anything .
Here is the current configuration:
C3850:
interface TenGigabitEthernet1/0/24
switchport trunk native vlan 11
switchport trunk allowed vlan 11
switchport mode trunk
interface Vlan11
ip address 10.100.11.250 255.255.255.0
Arista switch:
interface Ethernet14
interface Vlan11
ip address 10.100.11.253/24
Is there something I am missing or is it something more specific that needs to be added to the configuration?
marce1000
  - Check logs on both devices when a connection is attempted when configuring
    Perhaps these resources can provide insights , yet different configurations are used :
        https://www.youtube.com/watch?v=bvyLNM36pH8
        https://www.cs.colostate.edu/~fortega/fiu_html/fall16/cnt5415/labmaterial/notes/class20.html
  M.
chabot-isaac
For some reasons, even at default settings, making the connection from Ethernet14 -> Te1/0/20 seems to be working instead of 24.
Tried on another 3650 and worked fine, but on port 23-24 of my 3850 all trunks I tried to configure doesn't work...
Don't know whats the issue...
