ARP issue
bijay.swain
When I ping to one of the H3C comware switch in our network I don't get any reply .
all switches and my hosts are in default vlan .
I tried to debug on the destination H3c Comware switch to which I am pinging . I found below details which might be the reson I am not getting any reply from the switch.
*Aug 22 19:53:59:690 2017 PM-DC ARP/7/arp_send: Send an ARP Packet, operation : 1, sender_eth_addr : 3822-d626-c9d7,sender_ip_addr : 10.147.24.80, target_eth_addr : 0000-0000-0000, target_ip_addr : 10.147.24.254
*Aug 22 19:53:59:691 2017 PM-DC ETH/7/eth_info:
 Output L3 ethernet packet!
  ETHL3EncapHead need encap l2 head
*Aug 22 19:53:59:692 2017 PM-DC ETH/7/eth_send: Send an eth packet, interface: Vlan-interface1, format: 0, prototype: 0806, src_addr : 3822-d626-c9d7, dst_addr : ffff-ffff-ffff
*Aug 22 19:53:59:692 2017 PM-DC ETH/7/eth_info:
Eth L3 Output packet head is :
  ff ff ff ff ff ff 38 22 d6 26 c9 d7
  08 06 00 01 08 00 06 04 00 01
*Aug 22 19:53:59:693 2017 PM-DC RXTX/7/pkt:
From board 0: transmit packet from chip0,vlan1,Priority=0x7,len=46
*Aug 22 19:53:59:694 2017 PM-DC ETH/7/eth_info:
  ETHL3EncapHead resolve Arp error!
  ETHL3EtherOutput resolve Arp failed in encapheading!
*Aug 22 19:53:59:695 2017 PM-DC IPTRAP/7/debug_icmp:
SOCK RAW OUTPUT OK:
But some other devices are able to ping the switch .  what could be the issue
Reza Sharifi
Check the route table.  Do you have a route to this ip address (10.147.24.254)?
it is in same VLAN . that is in vlan1
Can you post the config from the switch you can't ping?
If I disable and enable any port in vlan 1 in the switch I get ping response for few hours and then again same issue starts.
