Arp question
darkbeatzz
Is there a way that you can stop arp replies on a cisco switch?
Giuseppe Larosa
Hello Mick,
I try to guess:
if your router or switch is answering ARP requests for IP addresses different then their own you need to disable proxy-arp
int vlan 5
no ip proxy-arp
if you want the switch to never answer to ARP requests even if for their own IP address is a different matter.
In this case you should use a VACL and deny traffic with ethertype = ARP protocol
0x0806 ARP, Address Resolution Protocol.
to be sure in both directions
However, not all switch platforms allow to use ethertype based ACL (catOS allows I think)
in this case all legitimate systems will need a static ARP entry to communicate with the switch
Hope to help
Giuseppe
