AS-5350 FAIL
ricardo-morales
hi a has a AS-5350 installed this weekend for something that i dont know fails. i Get the looger atach before reboot.
The problem was that de E1 Controller were out do not respond, even i could not make it telnet only ping. i get connected him by console port i make a write men, save the logg.
After this the in g0/0 does not have an ip address. can someone help me.
pradeepde
Level 5
Level 5
The only workaround at this point is to reload the box. You can monitor this with the show chunk output and look at the elements in use for the VTSP event pool. This number will probably keep incrementing all the time till you run out of memory.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/prod_release_note09186a008015a80e.html#wp312827
The following document explains the symptoms and possible causes of memory allocation failure (MALLOCFAIL), and offers guidelines for troubleshooting memory problems.
http://www.cisco.com/warp/public/63/mallocfail.shtml
smothuku
Level 7
Level 7
Hi ,
which IOS you are running in as-5350.
satish
