12-27-2018 10:01 PM - edited 03-08-2019 04:54 PM
Hi ALL,
In our cisco switches we have command like sh vlan to check interfaces are on which vlan & also sh ip int br to check which IP tag on which switch interface is there any same kind of command in cisco asa 5505 to check the interfaces on which vlan & what is the ip address configure on firewall interface ?
12-28-2018 12:13 AM
12-28-2018 12:16 AM - edited 12-28-2018 12:22 AM
show ip will get all the ip address assigned to ASA interfaces.
show arp will show you the IP to Mac binding learned via interfaces.
Abheesh
12-29-2018 03:01 PM
show switch vlan
show int ip brief
Keep in mind that the asa 5505 uses IPs on SVIs rather than on the physical interface itself
