ASA 5505 - How to allow SSH from outside host to inside hosts?
kjdoran01
I have a ASA 5505 with the basic license.  The three VLANs are inside, outside, and guest where guest has the 'no forward interface Vlan1' setting required on the third interface by the basic license.  The outside interface is a private LAN with access to the Internet.  On the outside interface is a host that we want to allow to SSH into hosts on the inside interface.  In the past I've used access-lists to do this on other routers but this ASA 5505 doesn't appear to use the access-list.  How can I allow SSH traffic from the host on the outside LAN to multiple hosts on the inside?
This is not for ASA 5505 remote management (that already works).
show startup-config
: Saved
: Written by enable_15 at 10:34:21.676 UTC Mon Nov 25 2013
ASA Version 8.2(5)
hostname ASA5505
enable password xxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxx encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 192.168.2.4 255.255.255.0
interface Vlan3
nameif guest
security-level 25
ip address 192.168.10.1 255.255.255.0
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu guest 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (guest) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 192.168.2.5 255.255.255.255 outside
ssh timeout 5
ssh version 2
console timeout 0
dhcpd dns 208.67.222.222 208.67.220.220
dhcpd auto_config outside
dhcpd option 43 ip 192.168.2.5
dhcpd address 192.168.1.5-192.168.1.254 inside
dhcpd enable inside
dhcpd address 192.168.10.5-192.168.10.254 guest
dhcpd enable guest
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username xxxxxxxxxx password xxxxxxxxxxxx encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:
Kim
You need a static command ie.
static (inside,outside) tcp 192.168.1.0 22 192.168.1.0 22 netmask 255.255.255.0
or
static (inside,outside) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
the first only does NAT for ssh specifically. If you want to allow other ports through then either do an individual port entry like the first statement just changing the port or use the second statement which allows all ports. Obviously you would still need to add an entry in the acl on the outside interface for each port.
I generally prefer to use to use the second option but either should work.
Jon
rfalconer.sffcu
Level 3
Level 3
The ASA does use access-lists. You have to create one, then apply it to the desired interface in the desired direction.
ip access-list ACL permit tcp eq 22
access-group ACL in interface outside
The ASA also uses object groups to make access-list management simpler.
Thanks for the help.  My statement above that the ASA 5505 doesn't appear to use access-list was poorly worded.  I've tried various combinations of access lists without success.  It appears the ASA ignores them.  From my limited understanding adding the entries you suggest should allow the traffice from the outside interface to the inside and because it is a tcp connection the inside interface should allow the traffic back to the source.  I'm sure it is something I'm doing wrong, but after putting the ACL in and assigning it to the outside interface it still doesn't allow SSH from the outside host to the inside hosts.
I'm not really familiar with using object groups and haven't tried that yet, but will start looking at it.
Below is a configuration with the changes you suggest.  I'm not able to SSH to the hosts on the inside.
show run
: Saved
ASA Version 8.2(5)
hostname ASA5505
enable password xxxxxxxxxx encrypted
passwd xxxxxxxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif guest
security-level 25
ftp mode passive
access-list OUTSIDE_IN extended permit tcp host 192.168.2.5 192.168.1.0 255.255.255.0 eq ssh
pager lines 24
mtu inside 1500
mtu outside 1500
mtu guest 1500
arp timeout 14400
access-group OUTSIDE_IN in interface outside
http server enable
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
dhcpd enable inside
dhcpd enable guest
webvpn
username xxxxxxxx password xxxxxxxxxx encrypted
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:
: end
ASA5505#
Kim
or
Jon
Jon,
Thanks!  That is what I was missing.  Works great.
Kim
