ASA 5505 vpn connection issues
mrfreethought
Hello I am having some issues with getting my vpn connection working on a new site. I get no internet connection when hooking up the asa. My current config is below. I have included a packet trace from my remote site to my main site. Any help would be appriciated, I am not very experanced in coniguring the devices.
hostname ciscoasa
domain-name .com
enable password w3iW.W8jLtqmhFnt encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
 nameif inside
 security-level 100
 ip address 10.10.10.1 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 72.xxx.xx.xx 255.255.255.0
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
 domain-name .com
access-list NONATACL extended permit ip 10.10.10.0 255.255.255.0 192.1.1.0 255.2
55.255.0
access-list VPNACL extended permit ip 10.10.10.0 255.255.255.0 192.1.1.0 255.255
.255.0
access-list OUTSIDEACL extended permit icmp any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/flash
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONATACL
nat (inside) 1 0.0.0.0 0.0.0.0
access-group OUTSIDEACL in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
http 10.10.10.1 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESPDESMD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map VPNMAP 13 match address VPNACL
crypto map VPNMAP 13 set peer 68.xx.xxx.xxx
crypto map VPNMAP 13 set transform-set ESPDESMD5
crypto map VPNMAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 13
 authentication pre-share
 encryption des
 hash md5
 group 2
 lifetime 86400
telnet 10.10.10.0 255.255.255.0 inside
telnet 192.1.1.0 255.255.255.0 outside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 192.1.1.6 192.1.1.4
dhcpd wins 192.1.1.6 192.1.1.4
dhcpd ping_timeout 750
dhcpd domain .com
dhcpd auto_config outside
dhcpd address 10.10.10.10-10.10.10.40 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 76.xxx.xxx.xx type ipsec-l2l
tunnel-group 76.xxx.xxx.xx ipsec-attributes
 pre-shared-key *
tunnel-group 68.xx.xxx.xxx type ipsec-l2l
tunnel-group 68.xx.xxx.xxx ipsec-attributes
 pre-shared-key *
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:229af8a14b475d91b876176163124158
: end
ciscoasa(config)#reciated
PramodKashid
I don't see a route in your config, add default route pointed to outside interface.
