11-05-2017 10:52 AM - edited 03-08-2019 12:37 PM
My network design consists of 8 remote locations in a Hub Spoke EIGRP. Each link is 10 gig or more.
Each remote site is a 3750-x connected to 2(4500-X) in VSS for distribution. From there the 4500's are connected to a 3750-X which contains connections to the server farm, call manager, 8 gig lag from the 5508 wireless controller, etc. It also contains a connection to the ASA / Internet connection (1 gigabit).
Would the ASA be better suited in EIGRP connected to the distribution switch using a Copper SFP? About 75% of the users are coming back to the Core using wireless.
11-05-2017 12:51 PM
not sure if I understand your design. The ASA is now the edge device connecting to the hub ? What do you want to change, fiber to copper ? Post a brief schematic drawing if possible...
11-05-2017 01:02 PM
Usually the firewalls are installed on the perimeter (edge of the network, facing to internet) or to protect the server farm. Do you have any diagram?
You could install a firewall between the distribution/core switch 4500 and the 3750 switches used for servers.
