12-18-2007 07:27 AM - edited 03-05-2019 08:04 PM
I wounder if anyone have a good solution to which ports to do a static on to open a XBOX360.
I have opened and made statics the 5 that microsoft says to open but still i get Moderate when i use the XBOX.
The ports i have made statics on are:
UDP 53
UDP 88
UDP 3074
TCP 3074
UDP 3330 (I think it was this one but I need to check when i get to the machine.)
No I do not want to use up a whole ip address and do a static on that.
Thanx for any help
Torbjorn
Solved! Go to Solution.
12-18-2007 11:03 AM
What do your statics look like? And the ACL?
Should be something like-
static (inside,outside) udp interface 88 [inside IP] 88 netmask 255.255.255.255
Then you need to allow the port in your ACL-
access-list outside_access extended permit udp any interface eq 88
I don't think you need UDP 53, that's DNS lookup. This is only needed id your host DNS.
HTH and please rate.
12-18-2007 11:03 AM
12-19-2007 05:19 AM
I feel so stupid.
I had totally forgotten to use interface instead of the ip adress
Thanx for reminding me.
Works like a charm.
