Showing results forĀ
Search instead forĀ
Did you mean:Ā
asa5505 with DMZ RESTRICTED
essaki_ihssan
hi
i have Cisco ASA 5505 Sec Plus Application With SW UL Users  HA 3DES/AES
i creat nameif inside and outside
but  when i creat nameif DMZ is restricted.
i want to know what that is mean "restricted dmz"and if it will work in my configuration:
my configuration is to install a SMTP Gateway server in DMZ for checking mail, and it will communicate with the outside and inside via port 25 and 110.
so my question is if the restricted dmz will work??
regards
jilse-iph
Seems, that the security plus licens is not (or not fully) activated. With fully activated SecPlus license, you should be able to configure up to 20 vlan interface with non of them restricted. Could you show us the output of "sh ver" of your ASA? Btw.: if i remeber correctly, you have installed a new license key, you have to reboot the ASA once to activate the new license.
