ASIC and CPU
iores
Level 6
Level 6
Is switch CPU used if destination MAC is unknown?
2 Accepted Solutions
M02@rt37
Hello @iores
When a switch receives a frame with a destination MAC address that is unknown (not in its MAC address table), the switch engages in a process known as "flooding" or "broadcasting" to find the correct path for the frame. During this process, the switch will temporarily use its CPU to make decisions about forwarding the frame.
Best regards
Joseph W. Doherty
It would depend on the switch.
As noted by the other posters, an unknown MAC is transmitted on all ports (except ingress port) for that VLAN.  This might be done in hardware, or software (CPU).  I would hope it's done on the former.
Interestingly, if you read up on the issue of unicast flooding, the problem is generally described by its impact to all the other ports getting the unknown unicast MAC destination traffic (like what would happen on a hub, i.e. losing the benefit of unicast on a switch) but also without mention of the switch's CPU being adversely impacted.  (BTW, this is something any Ethernet hub does all the time.)
Basically, and possibly, hardware that supports broadcast and/or multicast replication, across switch ports, would handle unicast flooding across ports too.
M02@rt37
Hello @iores
Best regards
I think Yes' form there cpu send frame as flood to all port in vlan same vlan source port assign.
MHM
Joseph W. Doherty
Yep, if the switch forwards in h/w (virtually every “switch” you buy today does), then flooding of BUM (broadcast, unknown unicast, multicast) traffic is done by the h/w too. If every BUM packet had to be punted out of the h/w path and up to the CPU for handling, then it would be trivial for malware to DoS the switch and take it offline by sending wirespeed BUM traffic. (Control-plane policers might mitigate against this by discarding packets, but only by breaking the principle that all BUM must be flooded. Twenty years ago, some switches that learned MAC addresses did so via the CPU, but it was soon discovered that this was a DoS attack vector. Nowadays MAC addresses are learned in h/w.)
Disclaimer: Bad answers are my own fault as they are not AI generated.
