ASR-1001-HX USB interfaces not showing up in invetory
CAOCX
Howdy Ya'll,
I'm currently working on my ASR-1001 router and I was going to use the USB ports and I was not able to find it on the my router inventory. I have looked around quite a bit and cant really find anything on it. Any thoughts on what this could be.
Thanks in advance.
Deepak Kumar
I don't think It will show you in inventory.
Try with
Show usb0:
Show usb1:
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank you for that. We did attempt that and it didn't show anything.
Leo Laohoo
Insert a USB flash drive and check the logs.  If the USB flash drive is supported by the router (or not), the logs will say so.
Hey, appreciate your response. Just tried it and it didn't work initially. Afterward we attempted formatting the removable USB drives on another Cisco device, moved them over to the ASR1000, and it seemed to work after that.
