04-26-2018 03:52 AM - edited 03-08-2019 02:48 PM
We have deployed a 1001HX running Denali Version 16.03.06.
We have configured ACL inbound on two interfaces: TenGigabitEthernet0/1/1 and Gi0/0/0
However, the ACL on Gi0/0/0 doesn't show any hit counters:
R#show ip access-lists 105
Extended IP access list 105
190 permit udp any eq domain any
200 permit tcp any any gt 1024 established
1790 permit object-group IPSEC-OBJ host X.X.X.X host Z.Z.Z.Z
1800 permit object-group IPSEC-OBJ host Y.Y.Y.Y host Z.Z.Z.Z
The ACL deployed on the Te0/1/1 interface show permit hit counters:
R#sh ip access-lists 111
Extended IP access list 111
20 permit ip 10.0.0.0 0.255.255.255 any (3383382 matches)
Both are deployed inbound.
Could it be that i don't see hit counters on ACL105 because it contains object-groups ??
How to see hits in ACLs that contain object groups ??
regards,
Geert
Solved! Go to Solution.
04-26-2018 04:13 AM
Strange. When i configured "service internal", and did "show ip acces list 105 expand", i got the following:
Object groups are not expanded yet.
Object groups expansion happens upon exiting from ACL configuration submode.
After
conf t
ip access-list ext 105
exit
exit
it works like it should.....
giving statistics even in normal view:
190 permit udp any eq domain any (1401 matches)
200 permit tcp any any gt 1024 established (12942158 matches)
04-26-2018 04:00 AM
04-26-2018 04:13 AM
After
conf t
exit
exit
