ASR 1002 and ASA firewall ,
vixal.vla
hello every one ,,
i have router ASR 1002 for my ISP , do i need ASA firewall for vpn and security , or ASR only ok for that ,,
2 Accepted Solutions
Paul Chapman
Level 4
Level 4
Hi -
Reasonably, yes you do need a firewall.  NAT does not equal firewalling.
PSC
Hi -
You should probably contact a VAR to help you properly size and spec a firewall for your needs.  Your internet speed, security requirements (IPS, NGFW, App Security, etc...), network design, and redundancy requirements need to be discussed before deciding which firewall to use.
If you have not previously worked with a VAR, ask your ISP if they can give you a reference to one.
PSC
Paul Chapman
Level 4
Level 4
Hi -
PSC
thank you so much ,,
do you suggest any firewall model with good price please
regards
Hi -
PSC
