03-02-2011 11:32 AM - edited 03-06-2019 03:51 PM
I currently have an ASR 1006 with a RP that keeps resetting. the following is the errors we received. has anyone encountered this before and how did you fix it. or does the router need to be repaired?
*Mar 2 05:14:23.111: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F1
*Mar 2 05:14:29.922: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:14:33.134: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:14:35.819: %CPPHA-7-START: F1: cpp_ha: CPP 0 preparing image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:14:36.333: %CPPHA-7-START: F1: cpp_ha: CPP 0 startup init image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:14:38.201: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:14:41.196: %CPPHA-7-START: F1: cpp_ha: CPP 0 running init image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:14:41.454: %CPPHA-7-READY: F1: cpp_ha: CPP 0 loading and initialization complete
*Mar 2 05:14:42.521: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1: cman_fp: Block cfg/0 of serial bridge 0 had I/O event 0x80
*Mar 2 05:14:42.521: %CMFP-0-SPI4_MUX_HALT: F1: cman_fp: SPI4 MUX driver has detected a critical error SPABUS0: Signal err_l Detected
*Mar 2 05:14:43.216: %IOSXE-6-PLATFORM: F1: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Mar 2 05:15:12.038: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F1
*Mar 2 05:15:11.485: %PMAN-3-PROCHOLDDOWN: F1: pman.sh: The process cman_fp has been helddown (rc 134)
*Mar 2 05:15:11.589: %PMAN-0-PROCFAILCRIT: F1: pvp.sh: A critical process cman_fp has failed (rc 134)
*Mar 2 05:16:26.383: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F1
*Mar 2 05:16:31.880: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:16:36.408: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:16:37.871: %CPPHA-7-START: F1: cpp_ha: CPP 0 preparing image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:16:38.333: %CPPHA-7-START: F1: cpp_ha: CPP 0 startup init image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:16:41.443: %CMFP-3-CPLD_ERP_ERROR: F1: cman_fp: An error has been detected on the ERP bus (cause 7, phase 6)
*Mar 2 05:16:43.176: %CPPHA-7-START: F1: cpp_ha: CPP 0 running init image /tmp/sw/fp/1/0/fp/mount/usr/cpp/bin/qfp-ucode-esp10
*Mar 2 05:16:43.433: %CPPHA-7-READY: F1: cpp_ha: CPP 0 loading and initialization complete
*Mar 2 05:16:44.499: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1: cman_fp: Block cfg/0 of serial bridge 0 had I/O event 0x80
*Mar 2 05:16:44.499: %CMFP-0-SPI4_MUX_HALT: F1: cman_fp: SPI4 MUX driver has detected a critical error SPABUS0: Signal err_l Detected
*Mar 2 05:16:45.230: %IOSXE-6-PLATFORM: F1: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Mar 2 05:17:13.835: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F1
*Mar 2 05:17:13.452: %PMAN-3-PROCHOLDDOWN: F1: pman.sh: The process cman_fp has been helddown (rc 134)
*Mar 2 05:17:13.556: %PMAN-0-PROCFAILCRIT: F1: pvp.sh: A critical process cman_fp has failed (rc 134)
03-02-2011 01:20 PM
Try reseating the RP. IF the problem persist, it's either you need to RMA the RP or the entire chassis.
