ASR 1006 ESP100 Upgrade
peteroseneff
I have an ASR1006 with the following confoguraion:
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    3d07h
0/0      SPA-1X10GE-L-V2     ok                    3d07h
1         ASR1000-SIP10       ok                    3d07h
1/0      SPA-1X10GE-L-V2     ok                    3d07h
R0        ASR1000-RP2         ok, active            3d07h
F0        ASR1000-ESP20       ok, active            3d07h
P0        ASR1006-PWR-AC      ok                    3d07h
P1        ASR1006-PWR-AC      ok                    3d07h
I need to upgrade the chassis with the ASR1000-ESP100 / ASR1000-SIP40  but
for ASR1000-ESP100 you have to upgrade power supply unit(s) form ASR1006-PWR-AC (1200W) to  ASR1013/06-PWR-AC (1600W).
The quesion is: does anybody try to incert ASR1000-ESP100 into ASR1006 chassis with 2 x ASR1006-PWR-AC? Does it work?
peteroseneff
I was told by cisco partner that the ASR1000-ESP100 will not work with ASR1006-PWR-AC.
We removed ASR1000-ESP20 and insert ASR1000-ESP100, powering the system with the same ASR1006-PWR-AC
on our own risk. ASR1000-ESP100 is working OK. Today I removed
both ASR1000-SIP10 and inserted ASR1000-SIP40 with 4 SPA-1X10GE-L-V2. No problem so far.
