ASR1002 MLP Bundle Problems
robvelc2014
Community Member
Hi fols,
We got ASR 1002 for use as LNS and move VPDN settings from 7204 to ASR1002... Looks like PPPoE interfaces (customers works pefect) but MLP Bundle cant establish 😞
Cisco Console Log:
Feb 13 05:00:13 104.234.254.1 21010: Feb 13 10:00:12.732: %CPPOSLIB-3-ERROR_NOTIFY: SIP0: cpp_cp:  cpp_cp encountered an error -Traceback= 1#adfdffd320bd4b50a075756a85bafaca   errmsg:7FB80973B000+121D cpp_common_os:7FB80C74C000+D8D5 cpp_common_os:7FB80C74C000+D7D4 cpp_common_os:7FB80C74C000+19A3E cpp_ifm:7FB81F747000+A158 cpp_mlppp_svr_lib:7FB815BBB000+C2F1 cpp_mlppp_svr_lib:7FB815BBB000+1CCA8 cpp_mlppp_svr_smc_lib:7FB815DF9000+2D28 cpp_common_os:7FB80C74C000+11E6E cpp_common_os:7FB80C74C000+118AA cpp_common_os:7FB80C74C000+116EB evlib:7FB80B72C0
Feb 13 05:00:13 104.234.254.1 21011: Feb 13 10:00:12.733: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: SIP0: fman_fp_image:  MLP bundle 174, link 170 download to CPP failed
Radius Log (look as well):
Fri Feb 13 04:59:41 2015 : Auth: Login OK: [[email protected]] (from client asr-lns1.xxxxx.com port 3445 cli BHVLPQ1004W lag-39:53)
Fri Feb 13 04:59:41 2015 : Info: Existing IP: x.x.x.x   (did  cli BHVLPQ1004W lag-39:53 port 3445 user [email protected])
Fri Feb 13 05:00:12 2015 : Auth: Login OK: [[email protected]] (from client asr-lns1.xxxxx.com port 3009 cli BHVLPQ1004W lag-39:53)
Fri Feb 13 05:00:12 2015 : Info: Existing IP: x.x.x.x   (did  cli BHVLPQ1004W lag-39:53 port 3009 user [email protected])
My Debug settings:
2# sh debug
PPPoE:
  PPPoE protocol events debugging is on
  PPPoE data packets debugging is on
  PPPoE control packets debugging is on
  PPPoE protocol errors debugging is on
MLP:
  Multilink fragments debugging is on
  Multilink events debugging is on
  First bytes of multilink packet debugging is on
VTEMPLATE:
  Virtual Template errors debugging is on
  Virtual Template subinterface debugging is on
#sh log | in MLP
:01:13.742: Vi109 MLP: Dropped link Vi110 from bundle [email protected]
Feb 13 10:01:13.742: Vi109 MLP: Dropped last link, removing bundle [email protected]
Feb 13 10:01:13.742: Vi109 MLP: Removing bundle '[email protected]'
Feb 13 10:01:15.392: Vi111 MLP: Request add link to bundle
Feb 13 10:01:15.392: Vi111 MLP: Adding link to bundle
Feb 13 10:01:15.392: Vi111 MLP: Requested bundle vaccess creation
Feb 13 10:01:15.392: Vi111 MLP: Determine clone source for SSS
Feb 13 10:01:15.392: Vi111 MLP: Link is Virtual-Access, clone from Virtual-Template 1
Feb 13 10:01:15.395: Vi111 MLP: Determine clone source for SSS
Feb 13 10:01:15.395: Vi111 MLP: Link is Virtual-Access, clone from Virtual-Template 1
Feb 13 10:01:15.396: Vi111 MLP: SSS connect, bundle interface Vi112
Feb 13 10:01:15.396: Vi112 MLP: Changing bundle bandwidth from 100000 to 2000000
Feb 13 10:01:15.396: Vi112 MLP: Interleaving disabled
Feb 13 10:01:15.396: Vi112 MLP: Ready to finish adding link Vi111 to bundle
Feb 13 10:01:15.396: Vi111 MLP: Computed frag size 7499992 exceeds MTU, changed to 1496
Feb 13 10:01:15.396: Vi112 MLP: Update bundle bandwidth 2000000 set 2000000
Feb 13 10:01:15.396: Vi111 MLP: Change transmit status from Init to Enabled, transmit links 1
Feb 13 10:01:15.397: Vi112 MLP: Added first link Vi111 to bundle [email protected]
Feb 13 10:01:15.397: Vi111 MLP: Updating bundle's PPP handle[0xCE000105] in SSS context
Feb 13 10:01:15.398: Vi112 MLP: Received segment updated message for bundle
Feb 13 10:01:15.402: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: SIP0: fman_fp_image:  MLP bundle 179, link 178 download to CPP failed
Feb 13 10:01:17.694: Vi112: MLP: Bundle has 1/2 desired links, requesting another
Feb 13 10:01:43.097: Vi111 MLP: Change transmit status from Enabled to Idle, transmit links 0
Feb 13 10:01:43.097: Vi112 MLP: No previous member for idle link in '[email protected]'
Feb 13 10:01:43.097: Vi112 MLP: Update bundle bandwidth 2000000 set 2000000
Feb 13 10:01:45.102: Vi111 MLP: Request drop link from bundle Vi112
Feb 13 10:01:45.103: Vi112 MLP: Removing link Vi111 from bundle [email protected]
Feb 13 10:01:45.103: Vi111 MLP: Change transmit status from Idle to Init, transmit links 0
Feb 13 10:01:45.103: Vi112 MLP: Bundle bandwidth 2000000 unchanged
Feb 13 10:01:45.103: Vi112 MLP: Dropped link Vi111 from bundle [email protected]
Feb 13 10:01:45.103: Vi112 MLP: Dropped last link, removing bundle [email protected]
Feb 13 10:01:45.103: Vi112 MLP: Removing bundle '[email protected]'
2# sh ppp multilink
Virtual-Access126
  Bundle name: [email protected]
  Remote Username: [email protected]
  Remote Endpoint Discriminator: [3] 4c60.de51.dd67
  Local Endpoint Discriminator: [1] asr1002
  Bundle up for 00:00:25, total bandwidth 2000000, load 1/255
  Receive buffer limit 12192 bytes, frag timeout 1000 ms
  Bundle is Distributed
  Using relaxed lost fragment detection algorithm.
    0/0 fragments/bytes in reassembly list
    0 lost fragments, 0 reordered
    0/0 discarded fragments/bytes, 0 lost received
    0x0 received sequence, 0x0 sent sequence
  Platform Specific Multilink PPP info
    NOTE: internal keyword not applicable on this platform
    Interleaving: Enabled, Fragmentation: Enabled
  Member links: 1 (max 16, min 2)
    BHVLPQ1004W:Vi125  (x.x.x.x), since 00:00:25, 7500000 weight, 1496 frag size, unsequenced
No inactive multilink interfaces
Border-ASR1002#sh users | in xxxxx
  Vi129        [email protected] PPPoVPDN     never
  Vi130        [email protected] MLP Bundle   00:00:06
NO IP ASSIGNED and this SESSIONs will be close in 30-50 sec. Then start again by circle.
interface Virtual-Template1
 ip unnumbered Loopback100
 no ip redirects
 no ip proxy-arp
 ip mtu 1460
 ip tcp adjust-mss 1420
 load-interval 60
 no peer default ip address
 keepalive 30
 ppp mru match
 ppp authentication pap chap xxx-netwrok.com
 ppp authorization xxx-netwrok.com
 ppp accounting xxx-netwrok.com
 ppp ipcp dns 8.8.8.8
 ppp multilink
 ppp multilink links minimum 2
 ppp multilink interleave
 ppp multilink endpoint string asr1002
end
interface Loopback100
 ip address x.x.x.x 255.255.255.255
end
#sh ppp  statistics
Type PPP Statistic                              TOTAL      SINCE CLEARED
4    Transition Packet Drop                      2          2
5    Interrupt Transition Packet Drop            5          5
14   PPP Handles Allocated                       16620      16620
15   PPP Handles Freed                           13971      13971
16   LCP Renegotiations                          17         17
17   NCP Renegotiations                          3          3
18   NCP Negotiations Failed                     348        348
19   PPP Encapped Interfaces                     4583       4583
24   LCP Timeout+                                2892       2892
25   NCP Timeout+                                89257      89257
26   LCP Timeout-                                793        793
27   NCP Timeout-                                9542       9542
28   Authentication Timeout                      1984       1984
29   Configure-Ack Id mismatch                   9          9
30   Configure-Nak/Reject Id mismatch            21         21
Type PPP MIB Counters                           PEAK       CURRENT
1    Links at LCP Stage                          13         2
2    Links at Unauthenticated Name Stage         240        0
3    Links at Authenticated Name Stage           4          0
7    Links at Local Termination Stage            2650       2647
8    MLP Links at LCP Stage                      1          0
9    MLP Links at Unauthenticated Name Stage     1          0
10   MLP Links at Authenticated Name Stage       1          0
14   MLP Links at Local Termination Stage        3          0
20   Successful LCP neogtiations                 14497      14497
22   Entered Authentication Stage                14497      14497
28   IPCP UP Sessions                            2650       2647
48   CHAP authentication attempts                2          2
49   CHAP authentication successes               1          1
51   PAP authentication attempts                 14495      14495
52   PAP authentication successes                7397       7397
53   PAP authentication failures                 6141       6141
95   Total Sessions                              2651       2647
96   Non-MLP Sessions                            2650       2647
97   MLP Sessions                                1          0
98   Total Links                                 2654       2649
99   Non-MLP Links                               2653       2649
100  MLP Links                                   2          0
Type PPP Disconnect Reason                      TOTAL      SINCE CLEARED
11   Missed too many keepalives                  177        177
12   PPP Renegotiating                           18         18
15   LCP failed to negotiate                     1694       1694
17   Received LCP TERMREQ from peer              1465       1465
18   Received LCP TERMACK from peer while OPEN   2          2
24   Removing MLP Bundle                         412        412
27   MLP Kill Link                               4          4
29   Lower Layer disconnected                    3187       3187
37   Received disconnect from Session Manager    174        174
54   User failed PAP authentication              6141       6141
55   AAA Server did not respond                  695        695
57   Authentication timeouts exceeded            2          2
If i try look show interface for two interface in bundle i see like this:
Border-ASR1002#sh int Vi24
Virtual-Access24 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of Loopback100 (x.x.x.x)
  MTU 1442 bytes, BW 2000000 Kbit/sec, DLY 100000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  REQsent: IPCP
  MLP Bundle vaccess, cloned from Virtual-Template1
  Vaccess status 0x44, loopback not set
  Keepalive set (30 sec)
  DTR is pulsed for 5 seconds on reset
Border-ASR1002#sh int Vi28
Virtual-Access28 is up, line protocol is up
  MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 100000 usec,
  Link is a member of Multilink bundle Virtual-Access24
  PPPoVPDN vaccess, cloned from Virtual-Template1
  Vaccess status 0x44
  Protocol l2tp, tunnel id 64648, session id 34181, loopback not set
Looks like normal. but in 30-60 sec this crashed... and sure we have not one customers with MLP... i hope we have around 20-30... so should be tonns MLP 🙂
Sure i lose few hours for find solutions but without luck. Nobody have exacly answer to this question.
I got abolutely working configuration from working NAS (7201 and 7204) and move it to ASR... thats what i have with MLP :((((
Can someone try help me investigate in figure our this....
I found same thread on ciscoforums where guys tell "need update ios" but someone update it and have same issue, so i hope issue not in IOS version.
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSAL-M), Version 15.3(2)S1, RELEASE SOFTWARE (fc1)
IOS XE Version: 03.09.01.S
System image file is "bootflash:/asr1002x-universal.03.09.01.S.153-2.S1.SPA.bin"
If you need anything else, like more debug or more info ... just ask me... i will wait there for your questions.
Thanks a lot.!
/// Update
Little bit more debug from bootflash:/tracelogs/cpp_cp_F0-0.log.7749.20150213111013
02/13 11:09:07.734 [errmsg]: (ERR): %CPPOSLIB-3-ERROR_NOTIFY: cpp_cp encountered an error -Traceback= 1#adfdffd320bd4b50a075756a85bafaca   errmsg:7FB80973B000+121D cpp_common_os:7FB80C74C000+D8D5 cpp_common_os:7FB80C74C000+D7D4 cpp_common_os:7FB80C74C000+19A3E cpp_ifm:7FB81F747000+A158 cpp_mlppp_svr_lib:7FB815BBB000+C2F1 cpp_mlppp_svr_lib:7FB815BBB000+1CCA8 cpp_mlppp_svr_smc_lib:7FB815DF9000+2D28 cpp_common_os:7FB80C74C000+11E6E cpp_common_os:7FB80C74C000+118AA cpp_common_os:7FB80C74C000+116EB evlib:7FB80B72C000+B8E7 evlib:7FB80B72C000+E1B0
02/13 11:09:07.735 [buginf]: (debug):
 -Traceback=1#adfdffd320bd4b50a075756a85bafaca   cpp_common_os:7FB80C74C000+11445 cpp_common_os:7FB80C74C000+D7D9 cpp_common_os:7FB80C74C000+19A3E cpp_ifm:7FB81F747000+A158 cpp_mlppp_svr_lib:7FB815BBB000+C2F1 cpp_mlppp_svr_lib:7FB815BBB000+1CCA8 cpp_mlppp_svr_smc_lib:7FB815DF9000+2D28 cpp_common_os:7FB80C74C000+11E6E cpp_common_os:7FB80C74C000+118AA cpp_common_os:7FB80C74C000+116EB evlib:7FB80B72C000+B8E7 evlib:7FB80B72C000+E1B0 cpp_common_os:7FB80C74C000+13B43 :400000+6061 c:7FB7FC394000+1E514 :400000+5CC9
02/13 11:09:07.735 [cpp-mlppp]: (warn): [cpp_mlp_tx_link_create:3260] cpp_ifm_tx_chan_create_on_if failed link=1563 (retval='CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory)
02/13 11:09:07.735 [cpp-mlppp]: (warn): [cpp_mlp_svr_bundle_add_link_cmn:5035] cpp_mlp_tx_link_create failed link=1563 (retval='CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory)
02/13 11:09:41.978 [cpp-ifm]: (ERR): cpp_ifm_tx_chan_create_on_if.806: failed to find channel for parent if_h 100-'CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory
02/13 11:09:41.980 [errmsg]: (ERR): %CPPOSLIB-3-ERROR_NOTIFY: cpp_cp encountered an error -Traceback= 1#adfdffd320bd4b50a075756a85bafaca   errmsg:7FB80973B000+121D cpp_common_os:7FB80C74C000+D8D5 cpp_common_os:7FB80C74C000+D7D4 cpp_common_os:7FB80C74C000+19A3E cpp_ifm:7FB81F747000+A158 cpp_mlppp_svr_lib:7FB815BBB000+C2F1 cpp_mlppp_svr_lib:7FB815BBB000+1CCA8 cpp_mlppp_svr_smc_lib:7FB815DF9000+2D28 cpp_common_os:7FB80C74C000+11E6E cpp_common_os:7FB80C74C000+118AA cpp_common_os:7FB80C74C000+116EB evlib:7FB80B72C000+B8E7 evlib:7FB80B72C000+E1B0
02/13 11:09:41.981 [buginf]: (debug):
02/13 11:09:41.981 [cpp-mlppp]: (warn): [cpp_mlp_tx_link_create:3260] cpp_ifm_tx_chan_create_on_if failed link=1563 (retval='CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory)
02/13 11:09:41.981 [cpp-mlppp]: (warn): [cpp_mlp_svr_bundle_add_link_cmn:5035] cpp_mlp_tx_link_create failed link=1563 (retval='CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory)
02/13 11:10:13.049 [cpp-ifm]: (ERR): cpp_ifm_tx_chan_create_on_if.806: failed to find channel for parent if_h 100-'CPP Interface Database' detected the 'warning' condition 'IFDB detected error in API': No such file or directory
0 Replies 0
