Using Cisco Cat-3650 as the Access-lyr device and Nexus as Aggregation
Imran Ahmad
Level 2
Level 2
Hello guys,
We are planning for a DCI. Currently we have cisco 3650 switches availble.  For DCI i am planning to order new Nexus 7000 series
my quation is - is it possible to use my existing cisco cat 3650 in the Access-Lyr and use the Nexus 7k in the Aggregation Lyr?
Also What is the deffence using Nexus 2000 and or Cat switches as the access lyr lyr devices when using Nexus 7k in the aggr lyr?
thanks
Reza Sharifi
Yes, there is no issue with connecting 3650 to 7ks.
The difference is that the 2ks need a parent switch(s) (5k, 6k, 7k, etc..) to operate and manage and they will be installed as blades to the parent switch.  On the other hand, the 3560 is a stand alone switch and will managed on its own. If you are trying to build a new data center, you want to use the 2ks as they are designed for data centers.
Thanks Reza
